Ford 850 front axle
Rjm54
New User
Looking for help with the steps needed to widen the stance on my 850 ! To help turning radius and stability!
The procedure for setting the width of the front axle is shown in
the Operators Manual as shown below.
<img src = https://i.postimg.cc/sxMxg0KW/Ford800-Wheel-Adj.jpg>
Widening the front wheel track may help with stability, but it will make the turning radius larger, not smaller. Depending on what type of work you plan for it you may look into widening the rear wheel track to match.
(quoted from post at 11:39:38 09/26/19) Widening the front wheel track may help with stability, but it will make the turning radius larger, not smaller. Depending on what type of work you plan for it you may look into widening the rear wheel track to match.
Thank you
