Ford Tractors Discussion Forum |
Re: Ford 3000 hydraulics
Author |
[Modern View] |
sotxbill
09-26-2019 16:15:28
When the little lever is flipped down in the draft mode....... There should be very little or no slack in the rocker.... but in the draft mode, yes, when pushed in, it should lift and be more sensitive to rocker arm pressure as the lever is move to higher, less sensitive when lever is moved to lower position. But again, its a lot of pressure from the plow..as it has to push the big spring in... if the spring end is adjusted too loose, you can push it in by hand and that is not correct. pull the pin out of the rocker and tighten up the spring end and take out the excess slack, reinstall the pin in to the rocker again.
and with no pressure on the rocker, it should lift when the bib lever is nearly to the top..
Now with the little lever pointed up and in the "position" mode,,, the lift should rise and lower incrementally with the big lever position being raised or lowered..
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Fast Shipping! Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ] |
Home
| Forums
Copyright © 1997-2019 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
