Hello.
Hydraulic problem on a Ford 3000 -74 model. about 2500 hours.
Position control seemes to work poorly: Nothing happens until the control quadrant is about 2 inches from the top stop. Then it begins to lift. It lifts to the top, and fast, but is not tested with more weight than an empty transport box.
Same symptom on an external cylinder.
The consequence is that the hydraulics become difficult to regulate as everything must be done within a very short area of ​​the lever. The picture shows the lever in the neutral position, slightly higher, and it lifts, slightly lower, and it lowers.
All responses are highly appreciated.
Regards
Regards
