Ford Tractors Discussion Forum |
Re: 801 overheats
Author |
[Modern View] |
belercous
09-25-2019 10:35:23
Wayne:
I'm not sure what the exact part was that cured the not start when hot problem. Since the parts were cheap I replaced the coil & plug wires, distributor cap, rotor, that little clip that goes on the dist. shaft & rotor (what the hell is that about? Oh, and the replacement part I bought from YT was junk, it broke when I tried squeezing it to make it tighter. Fortunately the old one was still good so it went back in.)
I also removed the starter & cleaned where it & the flywheel cover where they mated, & between the flywheel cover & the block. I replaced both terminal ends on the battery cables. I removed the ground cable & cleaned it & where it grounded to the frame. (The whole time my buddy kept saying it'd ground through the bolts & I kept saying not always. When I cranked it the engine spun over faster than it ever had. I grinned & he looked down & mumbled.)
Back to the current problem: The coolant had been in the tractor for at least 13 years & it was still bright green. Normally when a lot of sediment builds up in a block it is rust & colors the fluid orange. That & how easily it flowed when I put a hose to the block makes me think there's not much, if any, sediment in the block. The V belt driving the power steering pump needs replaced & it was kinda loose. The one driving the generator was a bit tighter, but both will be replaced. Hopefully, that will be the problem, but since it had two belts driving the water pump, I'm not so sure.
Thanks for the info about setting the timing w/o a light. I suppose the flyweights in the dist. are fixed so the timing advance is set by design.
I guess what I'll do next is replace the V belts (making sure they're tight), put it back together (leaving out the thermostat) & getting a test kit to see if the head gasket is leaking. If that's the case it'll take him several months to save up enough to have the head milled, valves replaced, seats reground & a new head gasket. (He's on disability & won't want to do all that, but I won't not do all that; the valve springs are 60 years old.)
Any idea how much that'll cost?
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Fast Shipping! Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ] |
Home
| Forums
Copyright © 1997-2019 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
