Company Logo Shop Now
TractorLinks.com
Order Ford 841 Parts Online
Re: Need Help Identifying Tractor 841 Powermaster??
showcrop
09-25-2019 05:16:10
The pic doesn't show it very well but it looks to me like a 1/4 turn brass valve. To check fuel delivery, shut it off, remove the drain plug from the bottom of the carb, put a one quart glass jar under it, turn the shut-off back on and watch the flow. It should run a pint in a minute or less. If it slows to a trickle, there is your problem. The gas in the jar should be clear. if cloudy you have water. If it is slow try it before that filter. If it is slow before the filter it is probably the screen in the tank. Tanks on 50 year old tractors often contain a lot of crud. I have had great success cleaning tanks out with a siphon.
Copyright © 1997-2020 Yesterday's Tractor Co.
