Company Logo Shop Now
TractorLinks.com
Re: Overheating
Sean in PA
09-24-2019 07:43:54
carb cleaner around the head or intake manifold will tell you if you have an external leak on the suction side, but not anything about any internal leaks. If you are not getting any oil in the radiator then the pressurized exhaust gasses still could be forcing their way past a bad head gasket and cause pressure in the cooling system. There are actually tests you can perform for testing for exhaust gases in the coolant that would tell you if that is what is happening.
https://itstillruns.com/test-exhaust-gases-coolant-7885485.html
gmartin
09-24-2019 10:28:09
 Re: Overheating in reply to Sean in PA, 09-24-2019 07:43:54
Thanks Sean in PA. I think Iíll try a compression check first and go from there. Iíd really be up the creek if it wasnít for this board.
Copyright © 1997-2020 Yesterday's Tractor Co.
