Company Logo Shop Now
Overheating
gmartin
09-23-2019 16:17:46
I have an 860 Ford thatís overheating. Radiator is about a year old. Removed thermostat to see if it made any difference and it did not. This radiator looses a lot of coolant out the overflow tube. I can fill it anywhere from full to 2 inches from the top and it starts running out of the overflow as soon as you start the motor. Nothing leaking from water pump & water looks like itís circulating when I look at it when the radiator cap is off so Iím guessing itís not the water pump. Replaced both hoses when radiator was replaced & ďflushedĒ the block with garden hose while I was there. Have not tried operating without the cap but might try that next. Anybody have any suggestions? Thanks(in advance),
Gary
sotxbill
09-26-2019 05:49:07
 Re: Overheating in reply to gmartin, 09-23-2019 16:17:46
Guys!!! you should be able to start the tractor cold,,, and let it idle with no radiator cap on... It SHOULD not blow out coolant. Removing a cap from a hot tractor can be hazardous, but cold????
And as it idles, you look for bubbles coming out the radiator, normally a sign of a slight head gasket leak... In the case of water being blown out,,, its a fully blown gasket, or big crack in the head... where ALL of the compression is getting blown into the water jacket, and then out the radiator. A fully blown gasket puts up to 120 lbs into the water jacket, and the cap is only 6 or 7 lbs on a stock ford cap, changed to 12 lbs on later models..
SO... if its blowing cold,,, run a compression check to see if one cyl is low,,, or two adjacent cyls are low so you know where to look for cracks when you pull the head off. Hopefully its just a failed gasket and not a cracked block from freezing, or a cracked head from overheating. replacing a cap when it blowing water out is a waste of time and money. And if he got a generic cap, it will be 13 lbs instead of the original 6 lb cap on the 3000...iirc.
Either way.. good luck and let us know what you find.
Sean in PA
09-26-2019 04:41:57
showcrop, if the coolant level is proper and everything else is normal, then there should be nothing immediately after a cold start that would cause enough pressure for the coolant to come out even if there were no cap on the radiator at all.
showcrop
09-26-2019 04:28:47
MarkB, I don't have a crystal ball like you do. Though you may be absolutely certain that it is not the cap but is instead the head gasket, and I agree that the gasket is the more likely cause, likely does not mean positively for the rest of us, and Gmartin has to spend hours and dollars to eliminate the head gasket possibility. Gmartin did the common sense right thing by eliminating the easy cheap possibility before going for the more likely major possibility. Most likely he had other business that he was taking care of on the same trip as all of us almost always do. Can you please advise where you got your crystal ball?
MarkB_MI
09-26-2019 05:47:13
 Re: Overheating in reply to showcrop, 09-26-2019 04:28:47
No crystal ball, just a basic knowledge of physics. Water has a relatively low rate of thermal expansion, so thermal expansion can't explain water blowing out on startup. So combustion gasses must be getting pumped into the water jacket.
Larry NCKS
09-25-2019 16:43:01
I'm sorry, but I'm betting there's more to it than just a bad cap. If you have coolant fill 2 inches down and it immediately starts coming out the overflow upon start up, you have a combustion gas intrusion into the cooling system.
The pressure of compression is much higher than the pressure in the cooling system even at normal operating temperature. Whatever is allowing combustion gas into the cooling system is not severe enough to allow coolant back into the engine.
gmartin
09-25-2019 13:36:13
All,
I went to town today (90 miles round trip) & bought a new radiator cap. Now the tractor wonít start. Put battery on charger & will try again tomorrow.
Again, thanks everyone for your help. I am really hoping itís the cap because it works better for both my budget and my talents.
Gary
MarkB_MI
09-25-2019 19:15:56
 Re: Overheating in reply to gmartin, 09-25-2019 13:36:13
It is not the radiator cap. Best case scenario is it's the head gasket, which is not particularly expensive or difficult to replace. Worst case you have a cracked head, but you won't know until you pull the head to replace the head gasket.
This site sells the head gasket alone for 20 dollars or with the valve cover and manifold gaskets for 42 bucks. Your local New Holland dealer probably has them in stock as well.
Sean in PA
09-25-2019 08:11:53
Pressure can be generated in other ways than just heat. He says that when he starts it cold it immediately begins to come out the overflow, so the most likely cause is a failure in the head gasket where the compressed exhaust gasses are going from the cylinder directly into the coolant.
MarkB_MI
09-25-2019 03:11:21
Sounds like a blown head gasket to me. Not such a terrible job on an 860.
showcrop
09-24-2019 19:02:05
The coolant cannot go out the overflow without pushing past the seal of the cap, which takes pressure, which takes heat. If it is pushing out the overflow as soon as it starts to run without generating pressure, it means that the cap seal is bad.
lonestarjeff
09-24-2019 17:56:47
Mine had an elusive overheat problem after I did a semi-restoration. If the other suggestions don't find your problem try enriching the carb mixture. I was just running it too lean.
showcrop
09-24-2019 15:11:13
Running out the overflow as soon as it starts running means that your cap is not sealing. Try a new cap.
gmartin
09-24-2019 16:42:48
 Re: Overheating in reply to showcrop, 09-24-2019 15:11:13
I donít understand but will give it a try and let you know.
Thanks,
Gary
Sean in PA
09-24-2019 07:43:54
carb cleaner around the head or intake manifold will tell you if you have an external leak on the suction side, but not anything about any internal leaks. If you are not getting any oil in the radiator then the pressurized exhaust gasses still could be forcing their way past a bad head gasket and cause pressure in the cooling system. There are actually tests you can perform for testing for exhaust gases in the coolant that would tell you if that is what is happening.
https://itstillruns.com/test-exhaust-gases-coolant-7885485.html
gmartin
09-24-2019 10:28:09
 Re: Overheating in reply to Sean in PA, 09-24-2019 07:43:54
Thanks Sean in PA. I think Iíll try a compression check first and go from there. Iíd really be up the creek if it wasnít for this board.
pinball
09-23-2019 16:45:48
first thing I would do is as soon as I start it feel the radiator top hose. it should take 2/3 minutes for it to start getting solid. if it starts to get solid immediately then you probably have a blown head gasket and if your getting water out the overflow as soon as you start your tractor then it could be that. your water level just needs about an inch of water covering to tubes. it will expand with temp and if you fill it to full it will dump water. what does your water temp guage do when you start it. I just got done with a 961 that had the same problem. I flushed the heck out of it. replaced a freeze plug that started leaking. got a lot of rust out that hole. finally got the temp to hold at 230 which is still to warm but a lot cooler than what I had. I finally determine for sure I didn't have a head gasket problem and ordered a new thermostat and radiator. now she runs around 170 all the time. I do leave the level down some as it still gets a lttle pressurized but doesn't spit out any water. if you are trying to flush your radiator you will have to add something to your water such a mean green ,vinegar, soap and water.etc to help clean it as well as to flush the coils from the outside to make sure you have a good air flow though it. good luck.
gmartin
09-23-2019 17:12:50
 Re: Overheating in reply to pinball, 09-23-2019 16:45:48
Iíll hope & pray itís not a head gasket & see if I can find some time to fool with it tomorrow. Thanks for the reply.
MarkB_MI
09-26-2019 03:24:07
 Re: Overheating in reply to gmartin, 09-23-2019 17:12:50
In my experience, prayers are ineffective when it comes to repairing blown head gaskets. YMMV.
Sean in PA
09-23-2019 16:38:21
Head gasket?
gmartin
09-23-2019 17:05:42
 Re: Overheating in reply to Sean in PA, 09-23-2019 16:38:21
Not getting water in the crankcase and I donít think Iím getting oil in the radiator, so didnít consider the head gasket. Whatís the best way to check the gasket. Compression test? Seams like I had someone tell me to spray carb cleaner around the head while itís running. Ever hear anything like that?
Thank you.
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor. ... [Read Article]
Latest Ad: Hiniker 1300 rear window frame looking for one closer to Iowa the better [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
