Need to add if the tractor has pto or dual power it has to have 3 point lift.
Both are powered by the secondary side of the main hydraulic pump.
I wouldn't say that it would have to have a 3-point lift. It would be pretty easy to route the main pump flow back to sump, and/or to the lube circuit.
Some questions came up about one that was stripped down to 5500 lbs. at a local tractor pull. Rule states tractor must have rock shaft housing, if factory equipped, to compete in stock class. Thanks for the responses.
