Company Logo Shop Now
TractorLinks.com
Injector questions..
Robert (ID)
09-22-2019 12:26:03
OK guys
I came up with a newer web 268 block from a 7710 to use on the Frankenstein 5000 that i'm putting back together. I will be using the 5000 Simms pump, head and manifolds etc etc.. I'm wondering what injectors to use? We had to hammer #4 out of the head, so I be buying a new set..
Dieseltech
09-22-2019 12:36:00
 Re: Injector questions.. in reply to Robert (ID), 09-22-2019 12:26:03
Both 5000 and 7000 series use the same 150 degree spray angle tip, main difference would be needle valve lift and hole size. Will you be using a turbo?
Robert (ID)
09-22-2019 13:15:20
 Re: Injector questions.. in reply to Dieseltech, 09-22-2019 12:36:00
Nope no turbo, The block and rotating assembly are for a turbo tho.. I don't think the SOS would take the extra HP.. The 5000 was an early version with a 233 it had porosity and coolant in to #4. I obtained this block for less then I could repair the original block..
Bern
09-22-2019 13:51:54
 Re: Injector questions.. in reply to Robert (ID), 09-22-2019 13:15:20
I would get injectors for a 5610 myself.
Robert (ID)
09-22-2019 14:22:22
 Re: Injector questions.. in reply to Bern, 09-22-2019 13:51:54
Thanks Bern,
I was thinking 5610 or 6610, did the 5610 have the Simms Pump?? Ive wondered about putting a rotary pump on this engine.. but a pump and lines isnt really in the budget..
Bern
09-22-2019 16:02:17
 Re: Injector questions.. in reply to Robert (ID), 09-22-2019 14:22:22
Both models used both inline and rotary pumps, depending on the year. I prefer the inline myself because it's more rugged and has less "gizmos" inside to give trouble.
Dieseltech
09-22-2019 14:59:30
Spec cards show early 5610 used the inline pump, and early type long spindle high spring injectors. Late use the DPS rotary pump with low spring body injectors.
Robert (ID)
09-22-2019 17:31:02
 Re: Injector questions.. in reply to Dieseltech, 09-22-2019 14:59:30
OK so ill start looking for a set of early 5610 Injectors. thanks for the help guys..
Copyright © 1997-2020 Yesterday's Tractor Co.
