Company Logo Shop Now
TractorLinks.com
Order Ford 4000 Parts Online
4 cyl 4000 - Lost Power - How to Troubleshoot?
Jerry Ward
09-21-2019 18:34:47
Hello,
My 1964 4000 gas lost power. It had a backfire and then coughed a bit and had trouble starting after that. The air cleaner had a bunch of water mixed in with the oil and the spark plugs were very black. Also, that carb main jet was set to 5 or 6 turns out.
I've replaced the oil in the air cleaner, changed the plugs and set the carb to about 2 turns. I will start and run, but barely has enough power to move itself.
Can someone give me some guidance on tracking down what the problem is?
Thanks,
Jerry
Deutz Lover
09-23-2019 17:50:18
 Re: 4 cyl 4000 - Lost Power - How to Troubleshoot? in reply to Jerry Ward, 09-21-2019 18:34:47
Before you do anything else put an inductive timing light on it and make sure it is in time. If you don't have one get a loaner from one of the big auto parts store. They should have one. This is just to make sure the distributor has not lost timing.
If this checks out take a look at the points and under the distributor cap. Make sure the points are clean and there is no condensation or carbon tracking on the cap. While it is running in the dark see if you have a strong spark from the high tension lead coming from the coil.
It is unlikely the rings would go bad suddenly, but check the oil and make sure you have not blown a head gasket. Also you can smell antifreeze burning in the exhaust. I smells like celery.
It is possible to have a leak between cylinders without water entering the cylinders. A compression gauge would tell.
If all the rest checks out you might have to take the valve cover off and see if the valves are properly timed and the camshaft gear has not jumped.
showcrop
09-22-2019 18:35:46
I just googled it and the forum discussion that came up said that spark plugs have been metric since the 1930s.
Jerry Ward
09-22-2019 17:09:39
I'm trying to find a compression tester on Amazon, but all the ones that thread in list metric adapters. I wouldn't think this engine would have metric threads for the spark plugs.
makoman
09-22-2019 05:34:06
That engine will run on 3 cylinders. Make sure you have good spark on all plugs. Might be fuel screen blocked.
RobCons
09-22-2019 05:24:53
I've got a 1963 year model 4000 with the carb set at 2.25 - 2.5 or so turns out as I recall. It runs fine. Start with basics such as fuel, spark, air, timing, compression.
showcrop
09-22-2019 04:17:46
Get a compression tester. It is not much money. Two turns out is just fine unless you are entering a tractor pull with it.
WayneIA
09-21-2019 20:12:19
"barley has enough power to move itself" -- 1 cylinder? 2 cylinders? Choke or no choke?? no throttle, some throttle???
tractorguy2
09-21-2019 19:36:53
Two turns out is not enough for a 172 engine.
Larry NCKS
09-21-2019 19:27:19
Sounda like a fuel or compression issue to me.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
