Company Logo Shop Now
Ford block I.D
idt-572
09-20-2019 14:35:51
I found 2 blocks, EONN6015AA AND C7NN6015R.
Can someone tell me what they are?
And will they work in a early 5000 ford? They look like the one in my tractor but with a bigger bore.
idt-572
09-24-2019 08:19:26
 Re: Ford block I.D in reply to idt-572, 09-20-2019 14:35:51
Thanks Guys..........
Sean in PA
09-20-2019 19:30:14
A Google search on E0NN6015AA says that it was used in the 5610, which would make it a 256 ci with 4.4" bore x 4.2" stroke, the same as the later 5000. The earlier 5000 (prior to 4/1/68) had a 233 ci with 4.2" bore x 4.2" stroke.
C7NN6015R looks to be a later 256 ci 5000 block.
Bern
09-20-2019 15:18:40
All I can tell you for sure is that the E0NN is 1980 or newer, and the C7NN is 1967 or newer.
Take a tape measure and measure the bore. If it's almost 4 1/2", it won't work on an earlier 5000 with 4.2" pistons. If it's closer to 4 1/4", then it *might* work. At that point you'll need to get out some more precise measuring tools to see if the block you have has been bored out or not. You'll also need to see if the pistons you have are standard or oversize.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: Shaw due all tractor [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
