Dave1962ford
New User
I have a 1962 Ford 641 Workmaster, have had it two years, always starts first try. A few days ago I was using it around the property starting and stoping occasionally. I stopped and turned it off for 30-40 mins and went to restart and nothing, headlights work bright, don t dim when I hit the starter ? I replace the solenoid and also tried a jump wire to see if the starter button wasn t grounding. Hooked it up to my truck and still nothing (the tractor was converted to 12 volt). I could sure use some advise on what else to try, this tractor has been kept up by the previous owner amazingly. I ve tried tapping the starter to see if it was stuck. Thank you in advance for any and all help and suggestions.
