Company Logo Shop Now
TractorLinks.com
Tractor won t crank
Dave1962ford
09-18-2019 19:05:26
I have a 1962 Ford 641 Workmaster, have had it two years, always starts first try. A few days ago I was using it around the property starting and stoping occasionally. I stopped and turned it off for 30-40 mins and went to restart and nothing, headlights work bright, don t dim when I hit the starter ? I replace the solenoid and also tried a jump wire to see if the starter button wasn t grounding. Hooked it up to my truck and still nothing (the tractor was converted to 12 volt). I could sure use some advise on what else to try, this tractor has been kept up by the previous owner amazingly. I ve tried tapping the starter to see if it was stuck. Thank you in advance for any and all help and suggestions.
Dave1962ford
09-19-2019 17:44:43
 Re: Tractor won t crank in reply to Dave1962ford, 09-18-2019 19:05:26
showcrop
09-19-2019 15:24:57
Dave, lack of solenoid clicking indicates a problem in the control wiring as opposed to the cables. start with checking the small wires.
Dave1962ford
09-19-2019 09:45:20
First off I said neither solenoid made a clicking, I meant neithervthe new not the old, my apologize. I jumped the battery to the started and it started to crank. I will check all contacts along the positive battery cable, through the solenoid to the starter, I m guessing that where my problems are. If not I ll be back but thank you all so much, I m only 62 but survivor of a major heart attack and use this for grass cutting and snow. Grew up driving numerous small cords around the barns I worked. This tractor was a gift to me from my wife and myself for having survived the heart problem and to make life easier. (How much I love being on my tractor can be our secret). Thank you all again
da.bees
09-19-2019 09:27:15
I completely agree,get out the test light and/or multimeter before getting out wrenches. You mentioned "tapping on starter" to see if it was stuck. Work's much better to put it in high gear and rock the tractor to unlock starter.
Dave1962ford
09-19-2019 05:38:55
Sorry, was suppose to say I found that odd that neither solenoid made any clicking sound
Sean in PA
09-19-2019 05:31:38
It has two solenoids?
Also, what is "ofd"?
showcrop
09-19-2019 05:12:40
Have you gone connection by connection with a test light to see where you have voltage and where you don't?
Dave1962ford
09-18-2019 20:10:05
Neither solonoid clicked and I found that ofd
Stevob671
09-18-2019 20:06:39
Try to jump directly to the starter to bypass everything else. Make tripple dog sure you are in neutral or do it while sitting on the tractor wich your foot on the clutch. Also make sure starter is well grounded to frame.
p.s. did either solenoid click when you tried it?
Copyright © 1997-2020 Yesterday's Tractor Co.
