TW-10 Hydraulics problem found.
KYCASE1
Just thought I would let you guys know what I found on the TW-10 hydraulics I posted about a few pages back. The reason for no pressure was the the release valve was stuck open because of several pieces of metal in between the ball and seat. The metal came from one of the bearings/bushings in the pump. Now to get parts and put it all back together. The cab will sure make you say a few not so nice words about the engineers from time to time.
Interesting - thanks for the follow-up.
The cab is designed to come off fairly easily should you have the available overhead lifting equipment. That's what I did usually whenever I had to work on the hydraulics.
I pull the right wheel off when I have to work in that area. If the wedges are stubborn I at least remove the rim/tire.
