4600 Fuel Pump
JacobMo
I have diesel fuel seeping from the inlet to the pump."see photo". Is there a gasket or some type of seal in or under this nut?
Thanks Jack
It looks like a previous owner may have tried to cut corners the last time it leaked by cutting off the end of the line and replacing only the compression fitting. I think that's why the line enters the fitting at an angle, because it was shortened. It is supposed to come straight down to the fitting.
