Company Logo Shop Now
TractorLinks.com
Order Ford 4610 Parts Online
Ford Diesel 4610 Temperature Gauge Circuit
Jack - Iowa
09-18-2019 05:39:19
Attempting to help on a temperature gauge problem on a 4610 Diesel.
Looking for any help with a schematic or knowledge of this system.
Thanks,
Jack-Iowa
Jack - Iowa
09-21-2019 14:27:49
 Re: Ford Diesel 4610 Temperature Gauge Circuit in reply to Jack - Iowa, 09-18-2019 05:39:19
Certainly not the answer one would expect! The green wire from the connector to the gauge was missing!
I think we have a communication problem regarding where the needle sets at cold but it's working now!
Thank you.
Jack
Bern
09-21-2019 16:19:59
 Re: Ford Diesel 4610 Temperature Gauge Circuit in reply to Jack - Iowa, 09-21-2019 14:27:49
Wiring diagrams can be very handy!
Thanks for the follow-up.
Jack - Iowa
09-18-2019 13:30:30
Yes, I did receive the diagram. It is the same as what I already had except better resolution.
He has a new multimeter on order. I suspect any real troubleshooting will not happen until he receives that. First thing is to determine what he has since it appears it is not standard.
Jack - Iowa
09-18-2019 10:18:16
Text sent.
Bern
09-18-2019 13:25:46
 Re: Ford Diesel 4610 Temperature Gauge Circuit in reply to Jack - Iowa, 09-18-2019 10:18:16
Diagram sent. Let us know what you find.
Jack - Iowa
09-18-2019 09:27:30
That is true for the 4610 gassers but apparently the diesels are different or his has been modified.
He tells me his sender unit has two terminals on it. I believe the gasser unit grounds through the shell of the sensor.
He also tells me with the key OFF, the gauge reads full right (HOT) and with the key ON, the gauge reads full left (COLD).
Does not make sense to me!
Bern
09-18-2019 10:04:59
 Re: Ford Diesel 4610 Temperature Gauge Circuit in reply to Jack - Iowa, 09-18-2019 09:27:30
The factory sending unit uses one wire, both diesel and gas. In fact, I'm pretty sure they're the same, and it does in fact ground through the body of the sensor.
Send me a text to three-6-zero, 7-zero-8, 8-two-8-zero and I'll send you a high resolution image of the factory wiring diagram. It's very simple.
Bern
09-18-2019 08:50:28
It's a pretty simple circuit. Key switched power comes into one side of the gauge, and the other side of the gauge grounds through the sending unit near the thermostat. Easy way to test would be to remove the wire at the sending unit and ground it - the gauge should peg hot. If it does, you likely have a bad sending unit. If it does not move at all, check for power to the gauge itself, or else continuity in the circuit from the gauge to the sending unit.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
