Company Logo Shop Now
Order Ford 5000 Parts Online
Ford 5000 clutch oil?
Bigfarmer32
09-17-2019 20:22:12
Hello I recently purchased a 1965 Ford 5000 with the 8 speed transmission. The steering box was shot and while changing it I noticed the clutch area had metal shavings and milky looking fluid in the case there was also a coter pin in an open hole on the bottom of the transmission I am wondering if that is suppose to be plugged and if there is suppose to be oil in it or if itís a dry clutch system?
Bern
09-17-2019 20:54:19
 Re: Ford 5000 clutch oil? in reply to Bigfarmer32, 09-17-2019 20:22:12
Clutch cavity is supposed to be dry. Oil is coming from either the front transmission seal or the engine rear main (which would usually be black). Cotter pin rattles around to keep the hole from plugging up so that oil can drain out.
Today's Featured Article - Oliver 4340 Plow Setup - by ShepFL. How to properly setup your Oliver 4340 plow plus many tips and pointers that may apply to many other brands of plows as well. ... [Read Article]
Latest Ad: Would like to find hay table for a John Deere 700 or 750 grinder mixer [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
