Company Logo (800) 853-2651 Shop Now
Order Ford 2000 Parts Online
1965 Ford 2000 diesel blowing air from the air intake stack
Bart CA
09-17-2019 08:05:26
There is some air blowing from the air intake stack.
It seems fresh air no exhaust smell
It is supposed to be vaccuum at air intake.
Engine runs well good power no smoke.
Any ideas ?
Thanks in advance
Bart
David G
09-17-2019 19:02:44
 Re: 1965 Ford 2000 diesel blowing air from the air intake stack in reply to Bart CA, 09-17-2019 08:05:26
Does it pop loudly?
sotxbill
09-17-2019 09:52:26
 Re: 1965 Ford 2000 diesel blowing air from the air intake st in reply to Bart CA, 09-17-2019 08:05:26
or intake valve too tight/burnt/damaged seat, and its blowing back on the compression stroke some or a lot.
Dieseltech
09-17-2019 09:46:58
On any engine that "pops back" on the intake side, I pull the valve cover and check all rocker arms. When an exhaust valve does not open as it should there will be trapped cylinder pressure that will then pop back through the intake side when that valve opens. Could be a too loose setting, push rod out of place, or a broken rocker.
Bart CA
09-17-2019 17:24:45
 Re: 1965 Ford 2000 diesel blowing air from the air intake stack in reply to Dieseltech, 09-17-2019 09:46:58
Thank you both for your replies
Greatly appreciated !
Bart
hightech1953
09-19-2019 20:57:44
 Re: 1965 Ford 2000 diesel blowing air from the air intake stack in reply to Bart CA, 09-17-2019 17:24:45
If it is just puffs of air I was told this was normal for a diesel.
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: model 55 JD combine 12 ft complete outside folding grain augar hercules motor [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
