Company Logo Shop Now
TractorLinks.com
Re: Need Ford Rim Clamps
Dean
09-17-2019 05:53:26
Be careful upon reassembly, as the so-called spacer clamp shown in the later photo can only be installed in a single position.
Installation in any other position will cause it to break upon tightening the bolt.
FWIW, the OEM fine threaded clamp bolts, nuts and washers are still available from CNH (or were a few years ago) but are quite expensive.
Dean
Lingcod
09-17-2019 06:46:50
 Re: Need Ford Rim Clamps in reply to Dean, 09-17-2019 05:53:26
Thanks for the tip Dean, I'll make sure to be get it oriented the right way. Would the bolts and nuts you mention that were available at CNH be the same ones being sold on the yesterdays tractors parts store listed as "Ford 801 Rear Rim Carriage Head Bolt and Nut"? Asking because the ones for sale on the YT parts page says they are for an 801 series but don't mention model 861.
Dean
09-17-2019 08:16:48
 Re: Need Ford Rim Clamps in reply to Lingcod, 09-17-2019 06:46:50
Haven't looked at the YT page but unlikely.
The YT bolts are most likely bolts for six loop rims.
The OEM PA clamp bolts are special fine threaded grade 8 (or harder) bolts and are shorter than six loop bolts.
The clamp bolts for vintage Ford PA rims buts be very tight to prevent noise and movement.
Dean
Dean
09-17-2019 19:05:38
 Re: Need Ford Rim Clamps in reply to Dean, 09-17-2019 08:16:48
They are not carriage bolts but are similar.
Yes, they will be expensive if still available from CNH. So too will be the nuts and hardened washers.
Dean
Copyright © 1997-2020 Yesterday's Tractor Co.
