Jeeper Creeper
New User
Hello all. New guy here with my first but likely not my last post.
I'd like to know if someone here could tell me what tractor I have. My Dad bought it when I was just a young pup and its sat under a shed for the last twenty years or so. To get started I'd just like to know what it is so I can be in the correct forum. This is the information I have on it:
On the flat spot behind the starter on the left side there's numbers that appear to be hand stamped its 640 or maybe b40
And below that is a diamond then 14014 followed by another diamond.
Upside down numbers cast below the oil filter is 11 then further to the right of that number is 4B3:1
On the block below the coil/distributor on the right side is EAE-6015- (? something I can't make out)
On the trans is NCA 7006.B
On the left side below the pto lever is NCA 4024B
The main color is red with the bodywork being a cream color.
It has a 4 speed transmission and a 4 cylinder valve in head engine.
For guages it has a large tach on top with smaller gauges of ammeter, temperature and oil pressure below.
From pictures I've seen I thought it may be a NAA Jubilee but it does not have that round Jubilee badge on the nose.
Thanks,
Jeeper
Thanks,
Jeeper
