Company Logo Shop Now
TractorLinks.com
Order Ford 600 Parts Online
Ford 3000 Ford 3600 engine swap
Hooder
09-16-2019 17:57:48
How many modifications need to be done to put a Ford 3600 diesel engine into an older 3000 diesel ?
Bern
09-16-2019 18:25:08
 Re: Ford 3000 Ford 3600 engine swap in reply to Hooder, 09-16-2019 17:57:48
Not much. As I recall, one of the major differences is the size and angle of the opening in the intake manifold. You cannot swap the manifolds, you'll need to adapt the hose. The exhaust manifold is also different, but can be swapped between the two engines.
Fordfarmer
09-16-2019 18:23:40
Will need the 3000's exhaust manifold, as a 3600's exits farther forward. Keep the flywheel from the 3000. (Flywheels stay with their respective transmissions.) Otherwise, should be a straight bolt in.
Bern
09-16-2019 18:26:55
 Re: Ford 3000 Ford 3600 engine swap in reply to Fordfarmer, 09-16-2019 18:23:40
Why does the flywheel need to stay with the tranny? If they both have the double clutch, they should be the same.
Fordfarmer
09-16-2019 20:46:59
 Re: Ford 3000 Ford 3600 engine swap in reply to Bern, 09-16-2019 18:26:55
If they use the same clutch, then yes, the flywheels should interchange.
Copyright © 1997-2020 Yesterday's Tractor Co.
