Company Logo Shop Now
TractorLinks.com
Order Ford 860 Parts Online
860 clutch disks
lonestarjeff
09-16-2019 08:48:40
I couldn't resist tearing down the old clutch assembly to see what the disks looked like, even though I don't have the repair parts :-(
lonestarjeff
09-25-2019 22:10:53
 Re: 860 clutch disks in reply to lonestarjeff, 09-16-2019 08:48:40
Yep, the release bearing on mine practically fell off the carrier.
rockman5159
09-25-2019 17:23:59
I just finished my 861 clutch replacement myself. Go ahead and take your medicine like a big boy. Shuck out from 3 to 4 hundred dollars and get a pre-assembled clutch pack with release bearing,pilot bearing, and double clutch assembly.You may want to check the release bearing carrier also. Mine seized up and and spun on the carrier and wore the shoulder down that holds the release bearing tight on carrier. It goes back together easier than you think
lonestarjeff
09-16-2019 14:11:54
It sat(disassembled)on my tailgate overnight to get the rust starting. It was surprisingly pretty clean when I pulled it apart.
lonestarjeff
09-16-2019 14:08:24
Release bearing chewed through the fingers......
Dean
09-16-2019 11:08:04
Doesn't look bad to me aside from a trace of oil/grease contamination.
Dean
showcrop
09-16-2019 10:31:21
It looks like the discs got rusted to the plates not too long ago.
Bern
09-16-2019 09:48:43
I don't see any problems. Why did you even replace it?
Ultradog MN
09-16-2019 15:50:49
 Re: 860 clutch disks in reply to Bern, 09-16-2019 09:48:43
He posted about this clutch on the NTC board. The throw out bearing froze up and ate the fingers off the drive clutch.
WayneIA
09-16-2019 10:51:51
My thoughts exactly.
Copyright © 1997-2020 Yesterday's Tractor Co.
