Company Logo Shop Now
TractorLinks.com
Order Ford 841 Parts Online
Re: 871 Gold Demonstrator/ 841 stuck in high on the combo
kirk-nj
09-16-2019 01:41:54
Unless you are trying to save the SOS just because it was your Dadís tractor, with the problems with the trans and it smoking you will spend more than the tractor is worth. The right side number was recall tracking number. Because your trans has ground off number itís likely that it was taken off a gold demo and a replacement was put on the gold demo with the restamped numbers. Just because your tractor has a little gold on the trans does not make the whole tractor a gold demo. Even if you found a 5 speed to swap in the motor will still need work. I would sell it or switch the best parts off it into the 841 and part the Sos tractor out
The Sherman combo handle was held in place with a lock washer and Allen head bolt. You can try as you said to tighten bolt and try to move. Itís likely you wit have to split the tractor and pull the Sherman for repair. It is possible to pop the steering box off and pull the top cover to make repair, I have done this only once and itís a fight to get it out of the steering box hole and back in, with trying to keep the forks lined up itís worse. A split is easier IMO
Copyright © 1997-2020 Yesterday's Tractor Co.
