Company Logo Shop Now
TractorLinks.com
Ford hundred series fuel valve
CTPhil
09-15-2019 18:12:26
I know that there are many threads about leaking fuel valves on hundred series tractors, and that the consensus is that new ones will inevitably leak. But what is the issue with those, bad O rings? Would they work as good as the original if right out of the box you changed the O rings?
CTPhil
09-21-2019 06:02:46
 Re: Ford hundred series fuel valve in reply to CTPhil, 09-15-2019 18:12:26
I just ordered and used these from McMaster Carr, not a leak in sight! These are for the shut off screw, valve to tank is dash number 115.
Limbhangers
09-20-2019 13:26:51
If anyone knows the size or has a part number for a better o-ring please post it.
5azzmonkey
09-20-2019 12:17:28
Makes one wonder what (crap) material is being used in the shutoff valves from the factory if Nitril (Buna-N) is working fine for you for 10 years ............
lonestarjeff
09-20-2019 09:46:42
I replaced my oring with nitril about 10 years ago. I started getting a slow drip while closed earlier this summer, but it stopped after a month or so. I bought the screw-type valve when I rebuilt the tractor but heard of the usual leak issues, so I replaced the oring from the get-go.
5azzmonkey
09-20-2019 07:54:28
Has anybody had better luck with trying a different material or shape o-ring instead of the standard Buna such as Viton and x or double x profile?
-Dave
jim tn
09-17-2019 12:09:59
I was just fixing to post about this problem. I hate to admit the gas I have lost due to these leaking valves and suspected it was the orings in them. Just put a brand new valve from Tractor Supply on and it started leaking in a few days. Guess I will drill out the stop on an old one the make the fix below. I think it is orings that are not restent to the gas.
Tim PloughNman Daley
09-16-2019 10:05:24
FORD TRACTOR 600/800 SERIES OEM OPERATOR'S/OWNER'S MANUAL:
Tim *PloughNman* Daley(MI)
Dean
09-15-2019 19:08:53
There are two styles of fuel valves used on hundred series tractors, screw type as pictured below and lever type.
The screw type can often be repaired if leaking. The lever type is more problematic.
Either type can be replaced without removing sheet metal, or rocker arm cover if the fuel system is OEM. All bets are off if the fuel line has been farmerized.
Dean
CTPhil
09-15-2019 18:31:16
Yes, that's the one. I was thinking I'd do that mod right out of the box.
nashranch
09-15-2019 18:24:16
If this is the valve you're referring to I Drilled mine out for more fuel flow and also doubled up the small O-rings in there. No more leaks. I did have to drill out the stop screw to get the valve apart. See my pics
This was on my 1955 640
Copyright © 1997-2020 Yesterday's Tractor Co.
