bigtom3993
I have a Ford 801 tractor that has the back hoe attachment on the back and bucket on The front , back hoe is ran by PTO pump on the rear , front bucket runs off tractor hydraulic, I had the tractor in first gear and was lowering the front bucket at the same time and then the tractor stopped moving, it did happen before and I raised and lowered the front bucket and the tractor would move again , I tried that trick again but no luck this time , I checked out further and not only will the tractor not move in any gear but the back hoe pump does not work that is attached to the PTO , does anyone have any ideas on what I can do ?
