identity of parts
ejensen
Have included pictures of my ford jubilee and a couple of parts on the tractor that I would like to know their purpose. The tractor originally had a bucket powered by the tractors internal hydraulics. Loader at present is powered by a front driven hydraulic pump
Shaun,
I remember when the tractor came new to the farm next door. It had some type of loader on it. Loader was off the tractor when I obtained it. Found a Paulson loader, built a bracket for the front mounted hydraulic pump and added a splined hub to front of engine.
Draft control is for plowing?
Chris
Left lever in that position is for position control. Push lever down is draft control. Yes draft for plowing dirt. Other might be deverter valve to desert power from 3PT to what you want to run with hydraulics
Hi Kirk,
Thank you. I know little to nothing about plowing. Soil where I live in Washington State is very rocky, ground seems to "grow" rocks to boulders.Have never had a plow on our Jube. At present have a cememt weight to keep back wheels on the ground for traction when using the front end loader
Chris
