Company Logo Shop Now
ford 3500 hydrualics
mnachesterron
09-11-2019 07:01:54
I have a 1965 ford industrial that has a 735 series loader and a 713 series backhoe, i found the hose schematic posted by Andy Wickiser and mine looks like the on with power to the hoe first then to the loader, the b/h is a earlier version than what belongs on this machine but has been working fine for several tears, i rebuilt a bunch of cylinders and the control valve assembly. now i need to set the pressures, the manual says to set the loader first then the b/h, i don"t believe i can do this because the pump supplies the b/h first, any input on this will be greatly appreciated, also does anyone have the procedure for setting the loader pressure, cant find the info for that again thanks for all the help Ron
mnachesterron
09-11-2019 12:28:45
 Re: ford 3500 hydrualics in reply to mnachesterron, 09-11-2019 07:01:54
[quote:77c2933b7c="Sean in PA"](quoted from post at 09:29:22 09/11/19) The relief valve in the backhoe control valve should be set higher than the one for the loader, so you should be able to adjust the loader first, but the order shouldn't really matter. If you find that the relief valve on the backhoe is lower than what the loader is supposed to be, then remove some shims in th ebackhoe valve fist to raise the relief pressure thjere and then adjust the loader pressure.
Did you change the backhoe control valve to true Power Beyond or did you just plumb them in series?[/quote:77c2933b7c][quote
this loader is newer than the b/h , and it does not have the switch control valve on the controls for the loader ,it is plumbed from the pump to the b/h, then to the loader then back to the left side verticle frame, which is used as the resivoir, if i guage the b/h at the controlvalve would i be safe to set the pressure relief at 1900 lbs then set the loader pressure at those controls to 1700lbs[/quote]
Sean in PA
09-11-2019 09:29:22
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: Shaw due all tractor [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
