NAA Oil Line Replacement/Repair
Hobo,NC
Location
Sanford, NC
I have a NAA I need to replace are repair the engine to oil pressure gauge oil line. It looks like its been squeezed together about mid way. It has excellent oil pressure I checked it at the oil filter mount...
What is needed to replace the line I know you have to remove the hydraulic pump there may be enoufh line to splice and put a union in the line...
The metal tubing like used to come with the
mechanical oil pressure gauges will work. I think the
tubing is still available from NAPA.
I remembered I have a junk engine in my stash I will remove the line on the engine for a look see to make sure its a common connection at the engine.. I did not want to remove the line and be stuck with it setting in a bay while I hunt down parts... :wink: I spec it must have sprung a leak upstream of the crimp sometime in its pass.. Its been setting for 10 years came to me somewhat stripped down after I cleaned the carb it came to me dissembled and in a coffee can I installed new ignition parts it fired right up and runs great everything works : )
Well NO it would only run with close to full choke I took the carb back apart did not see anything wrong with it so poked all the circuits with a wire again now it runs as it should without the choke applied...
He took it to a guy for a re-wire and a rattle can restoration : ( I guess the guy ran out of rattle can paint...
(quoted from post at 05:15:43 09/10/19)
Are tape it was all tapped up : ()
well, at least before he ran out of paint he got one of the few parts that should be BLACK painted RED.
I picked up a VDO kit from NAPA # 701-2154 and a coupling # G55400-0202 and tied it together without removing the hydraulic pump...
