Ford Tractors Discussion Forum |
3400 injection pmup
Author |
[Modern View] |
ufdaland
08-30-2019 16:24:55
trying to remove the injection pump for repair. I believe I have all lines , controls ,and attaching bolts removed including the three bolts to the drive plate, and the three mounting bolts . I still cannot separate the pump from the mounting plate . I have tried tapping with a hammer and tried to rotate the pump body with a punch and hammer all to no avail. it acts like there is still a bolt to be removed , but where . Any suggestions will be tried , maybe twice.
Justinscott33
09-09-2019 07:10:07
Re: 3400 injection pmup in reply to ufdaland, 08-30-2019 16:24:55
my 335 is the same. There is gears on there that you have three bolts holding to the pump. You ll have to take them off from taking the back cover off to get to them
Dieseltech
08-30-2019 17:38:24
Sounds like you have all hardware off. Pump should be sealed to timing case with an O ring, but someone could have used a gasket there. Try bumping the pump rear with a small wood block, maybe that will jar it loose. If a gasket with sealer on both sides was used, it will be glued on tight..
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit
... [Read Article]
Latest Ad:
Needing good 70 series fenders. No rust or dents preferred.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
