Strawboss19
New User
I have a 1976 Ford 535 industrial tractor. It has been sitting awhile but started right up. One problem though........I have
had the clutch stick to the flywheel many times, but this time, the clutch release rod will not move. I feel that the throw
out bearing is stuck. I can't get it to move. It is greased by a grease cup on the right side of the clutch housing. Any
suggestions on how to free it without splitting the tractor? Can you gain access to it if you remove the plate that bolts the
steering wheel to the top of the clutch housing? Any info would be appreciated. Thanks.
