Andrus Burr
Gents [and Ladies?], I just bought a 1955 Ford 860 feeling that I needed more power for my rotary cutter. The tractor looks great and supposedly has a recent engine rebuild, but the clutch is a problem. As you know it's a two stage clutch,...push down part way and you disengage the transmission clutch, all the way and you disengage the PTO as well. The problem is, I push down halfway and the transmission clutch doesn't disengage and the tractor just keeps merrily going along. If I stomp on the brakes it will disengage. And on the other hand, if I push the clutch all the way down the PTO will disengage but not the transmission, and again I have to stomp on the brakes. The problem is greater at high RPMs,...at 800 or 900 RPMs the trans clutch will often disengage, or just a tap on the brake will make it disengage. However at 1750 RPMs [to spin the PTO at 545] I have to REALLY stomp on both brakes to stop it. It sacred the wee out of me when I almost went through the back wall of the barn. So what do you think? By the way, I've already spent hours adjusting the linkage based on the owner's manual, and I do have an overrunning clutch which is working. Does this mean I have to split this nice shiny tractor and rebuild the clutch? Oh I hope not. Or is there something else going on? Thanks, Andy
