Need some help on my NAA I need to replace the lift ram arm (broken) I can get the lift arm shaft to go only so far.
In the parts book it looks like the shaft is bigger in the center so then it would be bigger then the bushings?
So how does it come out? Thanks
Whitch ever way trying to take shaft out bushing will have to come out with shaft. They can be quite snug. They are supposed to float in hsg but after 60 years. If possible flip shaft end for end to put worn part on top.
