Author |
[Modern View] |
Donnies
07-27-2019 18:48:50
I picked up a 515 with a no start condition. Was not getting spark so I dug in and now I'm stuck. I cannot find the points that fit anywhere. Want to get it fired and test run before I get too deep money wise. Can anyone help me out. It's a 3 cyl gas model DU224c.
Destroked 450
07-31-2019 04:57:14
Re: Ford 515 ignition in reply to Donnies, 07-27-2019 18:48:50
Used to run Mallory YL series distributors in old muscle cars, the red rotor button made me thing of Mallory but I didn't know they made those distributors for tractors. Learned something new today.
Can't help with the support group on Facebook, don't have Facebook but there's a pretty good group here.
Donnies
07-30-2019 18:20:16
You my friend are a bad@$$. Thank you very much! Now I need to find a support group for guys who buy ford tractors off facebook marketplace.
Destroked 450
07-30-2019 17:35:55
Mallory YL series! Didn't know they made a distributor for these tractors.
Go to Jegs, in the top search box punch in the part numbers.
Part # 650-25042 is the points $24.01
Part # 650-400 is the condenser $8.22
They don't offer much for those old distributors anymore.
If you break the cap or rotor button your done
Donnies
07-30-2019 16:13:43
It's a Mallory YL711AYH which from my internet search leads down another dead end.
Destroked 450
07-30-2019 07:26:39
Tisco sold aftermarket distributors made by Perstolite for 8N's, I wonder if they made one for the 3 cylinder models.
Sean in PA
07-29-2019 20:26:48
The original had both centrifugal (mechanical) and vacuum advances.
Donnies
07-29-2019 19:23:23
Soaking the bolts on it now to try to get it off without a cutoff wheel. Tomorrow it comes off one way or another!
Donnies
07-29-2019 19:16:04
Destroked 450
07-29-2019 19:13:29
It doesn't look like the replacement distributors I'm finding, is there a tag on the side with a name or info.
Donnies
07-29-2019 18:56:46
It has the mechanical advance on it. I'm not saying it's original because I'm not sure it is. However almost all the 515 and 4600 replacement units I have found also have mechanical advance. Thanks
Destroked 450
07-29-2019 18:03:37
That's not the original Ford distributor, doesn't have the vacuum advance, not sure who made replacement distributors for those models.
Donnies
07-29-2019 16:48:23
Somebody has to know what these parts are. Your help would be greatly appreciated.
Donnies
07-28-2019 17:10:54
Donnies
07-28-2019 17:10:17
Donnies
07-28-2019 17:07:05
Donnies
07-28-2019 14:35:27
Mine look very much like that however it has a brass/copper pin that comes up through the spring from the plate in the distributor, I think it can be removed but I am not sure. I will see if i can figure out how to post a picture. Also my condensor bolts down in the middle of the back side not the end, I tried that condensor and it wouldn't fit.
Sean in PA
07-28-2019 04:03:26
There were far fewer 515's made than its ag tractor sibling made at the same time period, the 4600. The 515 had the same engine as the 4600 so searching for ignition parts would be easier by searching for 4600 parts instead. In fact the same distributor was used for most 3 cylinder gasoline tractors from 1965 through at least the mid-80's.
Ford/New Holland part numbers:
points - C5AF12171C
condenser - C5NF12300A
rotor - C5NF12200A (superseded by 87727237)
distributor cap - E3NN12106AA (superseded by 87725501)
JoeM(GA)
07-27-2019 21:16:48
NAPA- points Part # ECH CS755 Product Line : Echlin Ignition Condenser Part #: ECH FA90 Product Line: Echlin Ignition
