1965 voltage regulator identifacation
marlin54
I have a 65 model and I think it has the original 12 volt generator and regulator...the generator has just 1 terminal marked F ....then it has this regulator with markings from right to left....B.....then F then WL then D then E.......are both of these original equiptment and where does the wires basically .... Does anyone know how wire it to make it charge ?
B = Battery live terminals.To "Batt" on Key starter switch, second to solenoid.
F = Dynamo Field.
WL = Dynamo Warning Light.
D = Dynamo Positive.
E = Earth/Ground.
Colours: Brown, Brown, Brown/Green, Brown/Yellow, Brown/Yellow, Black.
B B F WL D E
Battery
Field ( on generator)
Warning Lamp
Earth (ground)
I?m drawing a blank on the D. Was expecting it to be G for Generator (armature)
(quoted from post at 01:11:05 07/19/19) I have a 65 model and I think it has the original 12 volt generator and regulator...the generator has just 1 terminal marked F ....then it has this regulator with markings from right to left....B.....then F then WL then D then E.......are both of these original equiptment and where does the wires basically .... Does anyone know how wire it to make it charge ?
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto30129.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto30130.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto30131.jpg">
ook on back , around tach drive for another terminal.
