chevytaHOE5674
While mowing hay the last few weeks with my TW5 series 2 I noticed the discbine didnt "jump and swing" like it once did, but I kept going because the weather said go. Got it home and put the loader on and itll barely lift itself up unless you rev the tractor to the govenor. Tossed a gauge in the remote and only have 2000psi at 1400rpm and the service book says 2500 @1400. They said to remove and inspect the relief valve and add shims to get the pressure yp, to a max shim thickness of .08 but it was already at .075. Book also states add .01 to increase 100psi, which wont work with what I have in there.
So what should I be checking before assuming the pump is the culpret?
