Ford 4500 (was Ford 4400 tractor) getting there
mikewood869
Finally getting to put the tractor together again. Pulled the old 4400 front end off and attached the the 4500 front end on and that works. Today the 3 pt (not the arms) came off along with the fenders, rops (?) and the drawbar on the 4400. We then pulled half the loader frame off the old 4500 transmission and rear end and then loosely attached it to the 4400.
Tomorrow should be the loader. Got the right side of the loader frame on yesterday and got the noise and most of the hydraulic lines on tonight. The noise was lighter than we though.
Looking good. I am almost done with my 3600. I also did what you have done. I put the front end and oil pan off a 3500 on to my 3600 so I can use the 735 loader. Waiting on the power steering cylinder to come back from being rebuilt so I can put the loader on. I also have the big rear end with wet inboard brakes and having a hard time figuring out if I can make the roll over bar to fit. Need to make another mounting plate for it.
