FordIndustrialOwner
I have a 1961 Ford 4000 Light Industrial that is either out of adjustment or needs parts. It will not lift unless I remove the retainer from
the quadrant so I could move the touch control lever out of the quadrant and farther to the rear , like 3-4". I hear hydraulic fluid
whistling through the system when I have the touch control lever all the way back. What are the possible problems other than needing to go
through the adjustment procedure after pulling the cover and cylinder?
