notoriousisaacf
New User
I believe the clutch finally went out on my ford 861. I bought it last year, and the clutch always engaged all the way at the end of the pedal. I knew it was about out.
However, a few abnormal symptoms have me questioning what else may be wrong. Here they are.
1. When in neutral, when the tractor is cold, when i let the clutch out it starts to barely creep forward. Been doing this since day 1. Its completely in neutral, the knob goes up/down and is not in gear. It only does this very very gently, and only for 10 seconds or so. It doesnt make any odd noises.
2. Here in the last couple weeks sometimes the clutch would engage at half peddle and not be so sensitive.. as in it would kind of jerk into and out of gear. After using for a while, 10 minutes or so, the clutch would return to engaging all the way at the end of the peddle being let off.
3. (I think the actual clutch is obviously burned now because of the following...) it slips and grinds for 10 seconds or so when releasing the clutch until finally grabbing. Started doing this on a job. I got it on the trailer and back home but parked it since then.
So I wonder if theres a bigger problem with my transmission or the clutch linkage or something.
Or if these are common symptoms of a cluth going?
