Ford 860 gas throttle problem
oldtanker
OK, when through the Carb. Runs good. They way the prior owner had it set up would go to about 500 RPMS on idle but maxed out at about 1500 RPMs. So I got out the IT manual and started to adjust linkages. Now it runs right at 2200 no load and that's it . 2200 no matter where the throttle is.
Suggestions?
Thanks
Rick
When shut off does the governor arm move freely? Where do you have the other end of the rod that is on the throttle butterfly shaft?
