For Bob Reeves.. Bucket leveler pix
GB in MT.
[b:ea74b64f7d][i:ea74b64f7d]
Here is hopefully what you need to fab up for your 3000 .
If these are not good enough, I can email you and we can go from there with pho. calls, on your ??'s
Hope these work for ya!!!!
Gary
[/i:ea74b64f7d][/b:ea74b64f7d]
Thanks a million, hate to ask but any chance of getting a little better side view of the bottom of the rod. Can't tell if the PO drilled another hole in the bracket for the rod or?
(quoted from post at 18:53:05 07/09/19) Thanks a million, hate to ask but any chance of getting a little better side view of the bottom of the rod. Can't tell if the PO drilled another hole in the bracket for the rod or?
b:9154d6462b][i:9154d6462b]
Better shots of the rod going through the Hyd. Cylinder hookup at the bucket.
Was able to get some sun on it, should be able to see what's what, in these two pix.
Gary
[/i:9154d6462b][/b:9154d6462b]
Perfect, he did drill a hole for the rod. All the bends and twists just make everything line up more or less.
Thanks, just what I needed.
