Ford Tractors Discussion Forum |
4500 ford power steering adjustment
Author |
[Modern View] |
mrfabjr
07-03-2019 11:38:41
My 4500 ford frt. end loader and backhoe has a power steering problem. It will turn to the right easily but it takes all I can do to turn it to the left. I think I have found the adjustment for it but I am not sure. What I think is the adjustment for it is a small rod (5/16 I think) off of the top of the steering cylinder. It has a long nut with a lock nut on each end. Does this need to be longer or shorter for the proper adjustment? Is there anything else I need to know about it?
Thanks Floyd
mrfabjr
07-05-2019 08:37:24
Re: 4500 ford power steering adjustment in reply to mrfabjr, 07-03-2019 11:38:41
Thanks for the info. I will try that later this evening
Floyd
Fritz Maurer
07-04-2019 19:04:28
You said it steers easily in one direction, so I'm thinking we can rule out the pump. That rod is actually operating the control valve. With the loader securely blocked in the raised position, have an assistant turn the steering wheel lock to lock while you observe the action of the rod/spool assembly. Then, starting from a full right turn, slowly turn the wheel to the left until increased effort is noted, and instruct your assistant to hold it at that point. With the engine running, grab the rod with vice-grips, and move it in the direction required to make a left turn. Pay attention to the valve spool; it must move with the rod with NO lost motion. If when you move the rod and the system becomes pressurized for a left turn, the hydraulic system is OK and you need to adjust the rod in the appropriate direction. If you move the rod and no reduction of steering effort is noted, a cylinder overhaul is indicated.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
990 7 foot mower conditioner john deere hay rake pto driven john deere head carrier
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
