fatheroftwo
I have replaced all worn parts in the steering system, manual steering. The tractor has oversize tires, which may be a factor. When making a sharp turn one of the tires really digs into the dirt. The "tie rods/drag links" are not adjusted to the same length, hence the steering arms on top of the spindles are not in the same relative position when the steering wheel is centered. Am I right in assuming this is my problem? I have measured the distance between the tires in the front and rear of the front tires and it is ~60.5". Thank you in advance. I bought a service manual here but my daughter put it away and we cannot find it. lol
