Ford 4400 timing
mikewood869
Getting ready to pull the distributor to retime the motor, in the book it says that there s a arrow in the rectangular inspection opening, but I don t see it. Do you just line up "0" (I guess "0" is top dead center) in the middle of the opening then adjust the distributor? The tractor has electronic ignition and the vacuum advanced is still attached.
(quoted from post at 17:35:12 06/17/19) The arrow is on the plate, not the flywheel.
Thanks, I'll wipe of more grime off that plate. When we got the tractor, the tractor was missing the cover for that.
TDC is zero. 2 degrees is 2 degrees.
Do you know what TDC means? It means Top Dead Center. The degree scale is referenced and begun at this
point.
(quoted from post at 17:17:04 06/18/19) TDC is zero. 2 degrees is 2 degrees.
point.
Yes I do know what TDC means. I was wondering what BTDC means?
BTDC = BEFORE Top Dead Center. So, any number other than zero would be BTDC. You'll notice that the numbers
on the flywheel are only on one side of the zero, which just happens to be the leading side as you rotate
the engine in the normal direction of rotation. All gas and diesel timing events are done BTDC. None of them
are done ATDC.
