Question on 2000 in draft control
Mike(NEOhio)
Location
Newbury, Ohio
I used to pull my 1207 with it and used a remote line from the lift system. The manual said to use draft control which I did. When I pulled the knob to select the remote line it seemed to me that where the lift arms were positioned affected the neutral point between lift and drop. The manual doesn't mention that. Is that how it should work?
