Ford 800 Heat Shield Mounting
lmccollum
New User
I have a Ford 800, 1955 model and was wondering how to mount the heat shield. I have the shield, does it mount to a bracket or use U bolts around exhaust?
Thanks for any help,
(quoted from post at 07:07:29 06/14/19) I have a Ford 800, 1955 model and was wondering how to mount the heat shield. I have the shield, does it mount to a bracket or use U bolts around exhaust?
The front of it mounts to underside of fuel tank using 2 bolts that go into fuel tank. The rear of the heat shield bolts to rear fuel tank support . It basically goes above the muffler.
If this doesn't make sense I can take pictures for you . I just made a secondary custom heat shield to go under the rest of the fuel tank and put in a new heat shield above the exhaust.
Does this help?
