Tractor is a Ford 3000 and the problem is with the 3 point lift. When raising in position control, once the control handle gets to a certain point on the quadrant, the lift arms will not stop raising and continue all the way to the fully raised position. This happens when the handle reaches about 2/3 of the way up. With or without a load on the lift arms, it does the same. We have had the tractor for 10 or 12 years and the lift worked fine until last year when using the rotary cutter to clip pasture. The handle stays put when this happens and it happens every time the lift is raised.
I am not familiar with the details of the lift system. Any thoughts or ideas on what might be causing this would be appreciated. Tractor is about a 1974 year model.
Thanks,
Garry
Thanks,
Garry
