Started bush hogging pasture, made a couple rounds everything was operating normally, pto starting slowing down when starting cut eventually stopping, back out of grass and it resumes normal speed.
Removed top cover, drained oil and don't see anything obvious.The troubleshooting section of the FO-43 doesn't address this
specific symptom as I can tell.
I had a similar problem with it intermittently last season but started operating normally and finished the season. This is the first attempt with the bush hog this season.
Guess I will put it back together and attempt to check pressures per the FO-43. Any direction from ya'll is welcome. Thanks.
