tysmobiletractor
What I'm questioning is if I was to add an adapter plate for auxilary hydraulics to the back, is is possible to plumb in a filter housing that would attach to the inner fender.
I'm not expecting to be able to buy this.
I can buy the filter housing and lines.
My question is about the filter filtering the oil as it circulates, and also being able to still use the 3pt and auxilary hydraulics.
I think worst case cenario, I could have a shut off valve on the pressure side going to the filter. If this flow through the filter means loss of pressure to 3pt and or auxilary hydraulics, it could simply be turned on occasionally when neither 3pt or auxilary hydrualics are used.
Never seen anything available to do this.
Don't think it would be that hard.
But not sure of all details.
1st..... Is it possible?
2nd .... do I want to do this ... will benefits outweigh effort.?..
Glad to hear thoughts and especially any experience in this idea?....
I guess if was easier others would have done it?.... or ?...
