Ford 4110 Fuse Box
There isn't a fuse box.
There is one inlune fuse in the wiring
package behind the tach cluster.
I think it only protects the temp and
fuel gauges though.
In addition to what Ultradog has said, there is also another fuse for the headlights. If it is a US made tractor that one will be inside the light switch assembly. If it is a European tractor it will be behind the dash panel on the right side, below the back of the light switch.
