Company Logo Shop Now
TractorLinks.com
Leaking fuel line at injector pump
ed1
06-13-2019 03:08:49
Just had my pump rebuilt (74 5000 D Cav) and one fuel line is leaking at the fitting. I have it as tight as I can get it and it still weeps a little. Any ideas , need to replace line?
Thanks,
ed1
Dieseltech
06-13-2019 05:28:43
 Re: Leaking fuel line at injector pump in reply to ed1, 06-13-2019 03:08:49
I've had to swap banjo fittings before to stop fuel drips. Sometimes the line end will crack just inside the nut and line needs replaced. Those banjo bolts need to be REALLY TIGHT to get those washers to crush for a good seal also. Sometimes loosening/tightening line nuts five or six times will work too.
ed1
06-13-2019 10:20:32
 Re: Leaking fuel line at injector pump in reply to Dieseltech, 06-13-2019 05:28:43
Itís not the banjo fitting it is a fuel line itself, I got it as tight as I possibly could. May have to replace the line or take it off and clean the fitting.
Thanks for info
farmin101
06-13-2019 04:35:13
I'm not sure but there may be a seal in there that didn't seat right...another cause could be that when the line was put on that a small piece of dirt or sand got in... I'm assuming it didn't get cross threaded . If this line was replaced inspect the flare to make sure that it was done well ( no cracks and a good full seating flare)
showcrop
06-13-2019 04:30:10
I had this problem. I put old washers back in. Problem solved.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
